scotty - 12
That’s how it should have been from factory. Nice jobWay better launch limiter than stock I think
You have more ability in your pinky toes than i got in my extended family. Lol
ThxThat’s how it should have been from factory. Nice job
I did actually take a stock fuel table, and scaled it to line up pretty close with peak numbers from the map i was using, haven't had a chance to try it yet on my bike, but could be an option to get stuff pretty close. With closed loop fueling etc its pretty forgiving. You put your lambda target table in, and let the ECU do a lot of the work, and can refine from there after you look at how much lambda correction is actually taking place.Smith, your the man!
How difficult is it to convert or migrate data from my Woolich tune to MaxxECU? I would like to believe columns and rows are different values. If anything I think I might be able to build a excel sheet with tabs to convert. Or... You already have one.
Great work SmithabusaOne of the first guys to get a gen3 maxx setup, in Puerto Rico today made 241hp on motor on the dyno, this second system going to him as well.
Thanks!Great work Smithabusa
