shouldn't lose enough in one day to be noticeable.
The Russians are now taking motorcycle tires into space to fill them with Nitrogen, that way when they let the air out it all comes out in the vacume of space. Then fill with Nitrogen and safely return to inner space. I read that some where...and I check mine after every re-entry...and in space no one can hear you scream, or so I am told...![]()
the nitrogen molecule is a bit more stable than the mix of molecules.. It is certainly more stable than straight air in tires (we found this in the real world racing) We did not pin down the actual reason for the most stable gas mixture however.. could just be the moisture content for all I know..wondered about that.
anyone ever done tests to show benefits on bikes that you have seen?
Go with nitorgen and get your leak problem fixed![]()
someone should buy this and let us know if it works..
TireGard Wireless Motorcycle Tire Pressure Monitor System
Use Nitrogen - that's the ticket! It's waaay better than air. You should also try drinking hydrogen dioxide...it's waaay better than water!
CW
You can order up that summer air from Lord Humugus for $9.95 per lb.
WOW!!!! 195 bones think i will stick to the kicking an $1.15 gauge I am not that lazy yet![]()
