This time of year, your cold tire pressure changes are most likely caused by the large fluctuations in ambient air temperature.
Your bike and your safety must not be worth $195
It's the ability to know if you have a tire going down while you are riding.
Flat tire at speed can cost much more than $195
I think I checked mine once. they were still there!
No, I check mine about once a week. I've only added air to them one time and that was over a year ago.
An ACCURATE air pressure gauge is your ticket!!!!!
Installing 90 degrees offset air valve stems also helps to check air pressure more easily!
yea!! Steve (Busa159) has them... takes 1 second to check tires and you can use quality gauge without a bunch of crap trying to see or read the thing.. I finally just use my digital memory gauge.. gave up trying to see mine..OK, what are 90 degree offset air valve stems? Something that would keep from scraping my knuckles on discs and using two hands to hold down a hose?
nitrogen is not affected by "hot or cold"..pressures won't raise with heat or lower when cold.
That is exactly right!that is why it is no good in a tire on a bike??? I personally do not want to be cornering on tire filled with something that is not responsive to tire heat.
Way to bring old threads to life... ???
I'll tell you a true story from a couple of years back. I come to the bike in the garage after not riding for a couple of days. The rear is flat. I am like "Dang, where did I manage to get the puncture!". So, I inspect the tire - nothing. There is no puncture.
So, I unscrew the valve cap, spit on my finger and put the saliva on the valve. You geussed it, it blows the buble. So, I Inscrew the valve core, and I see a very small, tiny piece of dirt stuck on it. I blew it off, cleaned carefully, put it back, pumped the tire, and it never lost air since then. I was so glad I didn't have to buy a new one.![]()
WOW!!!! 195 bones think i will stick to the kicking an $1.15 gauge I am not that lazy yet![]()
CrashTestDanny has the SmartTire monitoring system and loves it. Instant tire pressure and temperature readouts. They stopped making the motorcycle version though.
That's the same one I have on my Busa. I'm looking at a different one for my FJR, only because SmarTire moved on to only making OEM TPS systems.
