I am trying to do what I can within reason and keep it reliable, and looking stock. It is my street bike.
I removed one of the fans with no issues. removed the gaurds off of the one I left on.
My DME stock replacement subframe showed up fri. Great looking piece. Only complaint is no hooks for the helmet. This is nice when I go somewhere and leave my helmet outside locked to the bike. Also some times on ocasion I will ride down town with no helmet and glasses on, but have my helmet straped to the side for when I go ride after going down town. Took it to the local fab shop I use and had a hook fabed up and welded on this mourning.
Bare stock subframe was 9lbs 10.5oz.
DME stock replacement subframe was 3lbs 6.25oz.
going to get a small 8 cell 1.7lb lithium battery put in the next couple days. Then going to measure the fully adjustable lowering links I have now and have a piece of aluminium bar stock cut and drilled to replace the fully adjustable ones. fully adjustable ones were a couple pounds.
Really want to remove the passenger pegs and brackets, but leave them on for the females once in awhile.
I really should of had the passenger peg brackets machined down some before I had them powdercoated. passenger peg brackets and aluminium passenger pegs is still almost 3lbs if I remember correctly.
