luded1
+1..... I like that too!!I am really liking that ABBA stand also.
I have this one-man PitBull stand. Worked great with my little R6, but when it came to the Busa, you have to be a Hulk, and I'm not weak, to get it up, the bike that is. I use a PVC pipe and slide it over the bar to give extra length for leverage. And you are correct, the other drawback is that you cannot see the right side spool and it's tricky to make sure you have it on there. I now have an 08 Busa, and still have the stock exhaust and I don't think the one-man PitBull will work with that huge exhaust on the left side of the bike. Looks like the ABBA stand is the tits.Both are excellent. I prefer the Pit Bull myself, but I've used the Redline before and it is also good.
That having been said, I see a problem using this "One-Man Stand" on the K8:
Watch the video to see this problem. The issue is confirming that the RIGHT spool (as you sit on the bike) is properly engaged in its spool arm before lifting the bike. It looks like a trivial exercise in the vid; but they are using a tiny little Triumph sportbike. On the K8 with stock exhaust, the right bazooka is so huge you would likely not be able to see the right spool (remember, you're standing on the left side of the bike when you use this stand). If you go ahead and lean over to the right to try to see the spool, you are really setting yourself up for the bike falling on its right side.
go to abba's website and it lists only one dealer in North America, Canada is all, you should be able to order from themWhere can I get a ABBA STAND in the USA.
Thank you.go to abba's website and it lists only one dealer in North America, Canada is all, you should be able to order from themWhere can I get a ABBA STAND in the USA.
Glad to see someone else from Scotland. I am with you i have the Abba stand and it is great.Much easier to use than a rear padock stand .Agree most of the items i wanted for the new busa i have bought from the statesI'm shocked we have got a product that you guys haven't.![]()
ABBA stands are terrific, you can clamber all over your bike when it's on one of these stands, one handed and one person lifting, best of all change your bike and just buy a new adaptor kit and your off.
They also make a front lift to go with the rear stand so you can take off wheels / shocks/ forks without any problems.![]()
+1Maybe one of our sponsers could become a distributor.
