Mythos
I did a manufacturer's suggested break in on my 14. I waited to 500 before changing oil for the fist time. Saw a lot of shimmering metal filings in the bottom of the drain pan. Second change same thing. 12,000 miles later, good performance, no leaks but it does burn a little oil (or at least it does something with it- I have to add 200ml every thousand miles).
I would like to do a WOT 11,000 rpm ring seating on the busa after a thorough warm up and then change the oil at ~20-30 miles. The people at the dealership are telling me to leave the oil in at least 250 miles because the friction caused by microscopic metal shavings will help my engine ware in. My feeling is there is going to be a hell of a lot more metal floating doing the max rpm ring seal than there would with a gentle break in.
Do you think changing oil too soon or too often when the bike is new is bad for the engine?
