hey bee
in my view even the shortes ride is too dangerous.
to check if a disc is bent over the max. tolerance (see manual) it is enough to push the bike by hand so far that the wheel made 2 turns.
then a bent disc (one is enough) pushed back the pads into its caliper enough that you wont feel any more pressure at the lever (foot pedal) - as we say here - you grip into emptiness.
at 2nd i would watch the front hoses.
if there is still the mudguard-cross-over-line (originally) is installed i would change that to a 2nd long line from left caliper to pump and bleed the system again.
the cross-over is a kind of air collector and that is not good (in my view a techn. nonsense) and causes problems with the brake again and again.
