well i can tell you one thing on the limiter clutch, i took it apart 2days before taking my engine out of the frame and apart. i took it apart to see how its made and see if the problem could be there. the splines on the shaft where a little damaged but i didnt think it could cause the issue... im still wondering tho. when i took it apart, i damaged the little circlip a little, so when i put it back together, i put the damaged circlip until id get a new one. went for a ride. next morning i tried to cold start the busa, it would not turn over, exactly the same as its doing on a hot start. i took the limiter assy out of the motor to look at it, the damaged circlip had come half out so the gears on the limiter where a little crooked on the shaft. i just replaced the circlip, put the assy back in the motor and it fired right up. So i know that if these gears are a little crooked, it will do the problem, im really wondering if theres too mutch clearance between my gears and the shaft of the limiter assy and when the starter applys torque while turning, the gears in the limiter assy are binding..... when i put back my motor together i will try another limiter assy to see. Im convinced the problem lies in the whole starter gear mecanism... by reading and reaserching ALOT on the furums, all the guys that have our exact problem are mostly 03's but all of them are 03's and up. 99-02 dont seem to have that problem, and they dont have the damm limiter assy....
viperam, if i recall you had the starter clutch or limiter assy replaced by the dealer.... an they later refunded you the parts, do you have proof they really had replaced it?
since i took the motor apart im going 1397 with an 08 crank.... no way i took the whole freaking motor apart for nothing lol, thats why i cant do more testing on the problem until im back together, should be 2-3 weeks
