Project "phoenix" has come to a halt...
ok...so here's what it looks like. I know, I know....it looks like COMPLETE disarray.
you know, that streetfighter look doesn't seem to be too bad. I'm kinda diggin it.
ok...now it's on to the good stuff. Here's where the external filter is set up.
'nother view. That hose that you see on top of the pump assy is the newer FI line that I installed. It runs from the upper part of the pump housing.
moved the T-joint on the fuel rail that was near TB#4. Sits in between TB 1 & 2.
shot of the filter. You can see the arrow pointin on the can...so it appears I got the flow right.
Pac - those are some smokin wheels...very Nice! And you take very good care of your fingernails...obviously a benefit from extended goat's milk use
and the up close of the oulet. Right above the new pump hose is where the T-joint used to be.
The filter sits slightly lower than the pump.
heheh...thanks, man! Don't tell no one, but I actually file 'em down after I clip 'em.
Wait a minute. Did I just say that out loud?
The wheels are courtesy of SageRonin and GMbusa. It wouldn't have happened without them.
Ok...so what say you, fellow members? Whaddya say?
Eagerly awaiting your input.
no...none yet, bro. I'm gettin real tempted to remove that external set-up and toss in the old fuel filter. Wanna see if it'll actually idle for me.
I got a newer ECU, injectors, coils and rectifier on the way. Not to mention a pump.
Geez...total cost of the rebuild thus far is $295 shy of what I originally bought the bike for. Dayum!
i think i would just try to move back my steps from when it was running , try taking the filter off first and go from there, it sounds like this is one of the smallest things that could be done
Sorry bro.....wish I had an idea, but I am rootin my arse off for ya.
Fingers crossed that the external filter is it.
thanks, man...
I hope it's just that too. Then mebbe all I'll need to do is replace the external with a freer flowing one.
